50
DateColumn Remote filter issue
IgGrid having the Date column. Also return modle property is DataTime datatype.But when doing grid remote Filtering it is not happeing for the date column.
When i saw in the query string filter text is passing as number.
Kindly advice
&filter(LastRun)=on(1557167400000)&page=0&pageSize=25&_=1557224260442
$('#Grid').igGrid({
dataSource: url,
DataSourceType: "json",
responseDataKey: "Records",
autoGenerateColumns: true,
autoGenerateLayouts: true,
columns: "[{"headerText":"Job ID","key":"Id","dataType":"number","width":"10%","hidden":false,"format":""},{"headerText":"Last Run","key":"LastRun","dataType":"date","width":"20%","hidden":false,"format":"MM/dd/yyyy HH:mm:ss"}]",
height: "500px"
public class ScheduledData
public int Id { get; set; }
public DateTime? LastRun { get; set; }
  • 17590
    Hello Rajesh,
    The date in the query string is represented in ticks so from my point of view everything seems correct.
    What I noticed is that in your igGrid configuration Filtering feature is not enabled. In order to ensure that the issue is addressed correctly I will need some additional information regarding your scenario. Perfectly, if you can provide me a working, isolated sample, where the issue is reproducible, this is going to be very helpful. Alternatively, please provide me your entire grid configuration, steps to reproduce and any details that you consider relevant.
