I want to control the color for each series for a barClustered Excel chart.
I have gotten as far as the statement below to retrieve the ChartFillBase, however, I can't find any documentation on how to actually set the colors or other characteristics of each series. How is this done?
series = Chart1.seriesCollection();series.item(0).fill().?????
The parameterless method would be the getter. You'll want to pass the chart fill that you want it to use. In all likelihood you want a solid color so you'd use the ChartSolidFill. The constructor for which takes a WorkbookColorInfo. e.g.
var clr = new $.ig.excel.WorkbookColorInfo("#FF0000"); series.fill(new $.ig.excel.ChartSolidFill(clr));
