2515
Issue with setSourceData with single point in series
I'm creating a chart that has a single series and a single point in the series. An example is:
chart.setSourceData('sheet!A1:B1', false), where the categories are in column A.
This method call is creating 2 series and is treating the value in B1 as the category value and the series point value. The chart is a barClustered.
Is there a way to work around this issue?
  • 280
    Hello Ray,
    If you need any further assistance on this, just let us know.
    Best regards,
    Hristo Popov
  • 54937
    Verified Answer
    The setSourceData method is a helper method that tries to do some of the logic that Excel does when you select a range and insert a chart but in some cases it differs. You could just directly create the series like this
    var series = chart.seriesCollection().add();
    series.name(new $.ig.excel.SeriesName(sheet, "Sheet1!A1"));
    series.values(new $.ig.excel.SeriesValues(sheet, "Sheet1!B1"));
  • 2515
    ChartTestSinglePoint.zip
    Sample for testing is attached. We are currently using 2018.2 but will be migrating to 2019.1.
