70
Loop through all selected rows in Virtualized igGrid
Could you please provide a code sample that would loop through all selected rows on a rowVirtualization enabled version 2017.2 igGrid and return the column value for a Column called 'UUID'? The grid has enableCheckBoxes set to true.
My code (included below) fails when attempting to access non-rendered rows. The only other reference I have found to this is at the following URL, but the answer isn't expanded on in any great detail and relates to an older version of the control.
https://es.infragistics.com/community/forums/f/ignite-ui-for-javascript/80275/virtualization-and-select-all-checkbox
Many Thanks.
var rowId;
var securities = new Array();
var rows = $("#SecurityGrid").igGridSelection("selectedRows");
$.each(rows, function (ix, el) {
rowId = el.element.attr("data-id");
var uuid = $("#SecurityGrid").igGrid("getCellValue", rowId, "UUID");
securities.push(uuid);
