125
Iggrid with inline edit and Row edit dialog box for specified column
Hi all,
I have a IgGird with some inline editable columns. Now I want to display a long text in the same grid. As the text column contains more length, I would like to display this column in a pop up window to feasible for read and edit the text value.
So I went to rowedit dialog box feature of the Iggird (https://www.igniteui.com/help/iggrid-updating-roweditdialog), but it affected the existing editable columns. Now the gird displays all the editable columns in a dialog/popup, so my existing features of the grid is affected.
Now my requirement is, I want to display only one editable column in the popup/dialog box and other editable columns should be in inline edit mode.
kindly help me for to resolve this issue ASAP.
Thanks in advance.
  • 23953
    Hello Lakshmi,
    The easiest way is to use a custom dialog that will pop up only when the user clicks on the "User Comment" cell and will trigger a row edit when user clicks on other columns.
    Here is an example definition of the dialog:
    <div id="dialog" style="display:none">
    <textarea id="titleValue"></textarea>
    <input type="button" id="save" value="Save"/>
    </div>
    The decision whether to open the custom dialog or inline editing you can do in the igGrid.cellClick event. Here is an example:
    cellClick: function (evt, ui) {
    var colKey = ui.colKey, cellValue;
    rowKey = ui.rowKey;
    $("#grid").igGridUpdating("endEdit", false);
    if (colKey === "Title") {
    $("#dialog").igDialog({
    state: "opened",
    height: 160,
    width: 220
    $("#titleValue").val($("#grid").igGrid("getCellValue", rowKey, colKey));
    return;
    $("#grid").igGridUpdating("startEdit", rowKey, "Title");
    And the button "Save" click handler:
    $("#save").on("click", function (evt, ui) {
    $("#grid").igGridUpdating("setCellValue", rowKey, "Title", $("#titleValue").val());
    $("#dialog").igDialog("close");
    4428.igGridUpdating_RED.zip
    I'm attaching a working sample for your reference.
    Best regards,
    Martin Pavlov
    Infragistics, Inc.
