30
IgGrid to Excel export
My requirement is to display grid by using search parameters and on click of export button, iggrid datas will be exported to excel. For that export , i have added below scripts.
<script src="">www.igniteui.com/.../script>
<script type="text/javascript" src="<%= Url.Content("~/Infrastructure/Scripts/infragistics/infragistics.core.js")%>"></script>
<script type="text/javascript" src="<%= Url.Content("~/Infrastructure/Scripts/infragistics/infragistics.lob.js")%>"></script>
<%--<script type="text/javascript" src="<%= Url.Content("~/Infrastructure/Scripts/infragistics/infragistics.dv.js")%>"></script--%>
<script type="text/javascript" src="<%= Url.Content("~/Infrastructure/Scripts/modernizr-2.8.3.js")%>"></script>
<script type="text/javascript" src="<%= Url.Content("~/Infrastructure/Scripts/infragistics/infragistics.loader.js")%>"></script>
<script src="../../Infrastructure/Scripts/jquery/jquery.ui.core.js"></script>
<!-- Required for igGridExcelExporter -->
<script type="text/javascript" src="<%= Url.Content("~/Infrastructure/Scripts/infragistics/infragistics.documents.core.js")%>"></script>
<script type="text/javascript" src="<%= Url.Content("~/Infrastructure/Scripts/infragistics/infragistics.excel.js")%>"></script>
<script type="text/javascript" src="<%= Url.Content("~/Infrastructure/Scripts/infragistics/infragistics.gridexcelexporter.js")%>"></script>
Search and grid export is working for the first time, But after that even search is also not working. On debugging the application, i am getting script error which is due to infragistics.excel.js.
jquery.min.js:10 Uncaught TypeError: b.toInt32 is not a function
at Class.s (eval at <anonymous> (jquery.min.js:3), <anonymous>:184:10134)
at Class.g4 (eval at <anonymous> (jquery.min.js:3), <anonymous>:25:15879)
at Class._init3 (eval at <anonymous> (jquery.min.js:3), <anonymous>:31:3994)
at Class._init2 (eval at <anonymous> (jquery.min.js:3), <anonymous>:31:3836)
at Class._init1 (eval at <anonymous> (jquery.min.js:3), <anonymous>:31:3767)
at Class.init (eval at <anonymous> (jquery.min.js:3), <anonymous>:31:3703)
at new Class (eval at <anonymous> (jquery.min.js:3), <anonymous>:232:1028)
at eval (eval at <anonymous> (jquery.min.js:3), <anonymous>:87:17624)
at eval (eval at <anonymous> (jquery.min.js:3), <anonymous>:89:1004)
at eval (<anonymous>)
Please suggest a solution for this.
  • 16310
    Thank you for posting in the Infragistics community and for the provided resources !
    However, they don't tell much about the error as it comes from the minified version of juqery. Anyway, I noticed that alo9ng with all the required Infragistics recources, you are loading the Infragistics.loader.js as well. Basically, you either load all resources in the conventional way ( like you do with infragistics.core.js), or use the igLoader to load everything needed. Please stick to one of those approaches, and I recommend you to remove the Infragistics.loader.js and load recources in the traditional way.
    Then it will be helpful if you confirm if the error is still shown, or ideally provide a sample that reproduces the issue. All other details are helpful to know:
    • exact version of the Ignite UI for JavaScript library used
    • does the error show on other samples ?
    • does the error show on all browsers ?
    Hristo
