Hi, I am using IgGrid
i am facing one issue, when i have to edit the column value either 0 or 1
i have to able type 0.5 ect. how to avoid typing dot(.)
using the below code
name: "Updating", enableAddRow: false, enableDeleteRow: true, enableCheckBoxes: true, editMode: "row", autoCommit: true, columnSettings: [ { columnKey: "RXClub", editorOptions: {type: 'number', minValue: 0, maxValue: 1} }
]Thanks in advance
Robin Bronston D
Hello Robin,
There are some minor modifications that have to be made to the code you have provided and it would prevent the user from being able to use floating-point numbers:
Here are two possible grid configurations: the first one has a number column that accepts only 0 and 1, and shows them without any additional formatting; the other one uses a boolean column instead and renders checkboxes.
I have provided the whole initialization configurations so you could see where the grid options have to be declared, and where the Updating ones should be:
A number column without checkboxes:
$("#grid").igGrid({ dataSource: ds, responseDataKey: "results", primaryKey: "ProductID", autoCommit: true, columns: [ { headerText: "Product ID", key: "ProductID", dataType: "number", width: "25%"}, { headerText: "Product Name", key: "ProductName", dataType: "string", width: "25%" }, { headerText: "Category", key: "CategoryName", dataType: "string", width: "25%"}, { headerText: "Available", key: "Available", dataType: "number", width: "25%" } ], features: [ { name: "Updating", editMode: "row", columnSettings: [ { columnKey: "Available", editorOptions: { dataMode: "int", minValue: 0, maxValue: 1 } } ] } ] })
A boolean column that shows checkboxes instead of zeroes and ones:
$("#grid").igGrid({ dataSource: ds, responseDataKey: "results", primaryKey: "ProductID", renderCheckboxes: true, autoCommit: true, columns: [ { headerText: "Product ID", key: "ProductID", dataType: "number", width: "25%"}, { headerText: "Product Name", key: "ProductName", dataType: "string", width: "25%" }, { headerText: "Category", key: "CategoryName", dataType: "string", width: "25%"}, { headerText: "Available", key: "Available", dataType: "bool", width: "25%" } ], features: [ { name: "Updating", editMode: "row" } ] })
If you need any additional assistance, feel free to contact me.
