1145
Editing row clears read only column
I have a grid with 3 columns. The first is one we use to create a unique index for each row and is hidden. The second column is SampleID and contains a pre-assigned value that is read only. The third column, "Part" contains a combo that lets the user select a value. In my actual code I have a formatter and stuff but for the sake of demonstrating my problem it's irrelevant, so not included...
The way the grid should work is that the user will be given a list of "SampleIds" and for each SampleID the user should select a "Part".
The problem is when the user selects a Part, the sample column in that row gets changed to null. I can't figure out why... The SampleId should remain unchanged.
Code example follows:
<!DOCTYPE html>
<html>
<head>
    <meta charset="UTF-8">
    <title>Grid Test</title>
    <link href="Content/themes/infragistics2012/infragistics.theme.css" rel="stylesheet">
    <link href="Content/structure/infragistics.css" rel="stylesheet">
    <script type="text/javascript" src="Scripts/jquery-1.9.1.js"></script>
    <script type="text/javascript" src="Scripts/jquery-ui-1.10.2.js"></script>
    <script type="text/javascript" src="Scripts/infragistics.core.js"></script>
    <script type="text/javascript" src="Scripts/infragistics.lob.js"></script>
        $(document).ready(function() {
            var gridOptions = {
                "mergeUnboundColumns": false,
                "enableUTCDates": false,
                "width": "100%",
                "localSchemaTransform": false,
                "autoGenerateColumns": false,
                "autoCommit": false,
                "dataSource": [{
                    "SampleId": "88-PR0813201800595",
                    "PartId": 0
                    "SampleId": "88-PR0813201800596",
                    "PartId": 0
                    "SampleId": "88-PR0813201800597",
                    "PartId": 0
                    "SampleId": "88-PR0813201800598",
                    "PartId": 0
                    "SampleId": "88-PR0813201800599",
                    "PartId": 0
                "responseDataKey": "Records",
                "primaryKey": "Index",
                "columns": [{
                    "key": "Index",
                    "dataType": "number",
                    "headerText": "Index",
                    "hidden": true
                    "key": "SampleId",
                    "dataType": "string",
                    "headerText": "Sample Id"
                    "key": "PartId",
                    "format": "combobox",
                    "headerText": "Part"
                "features": [{
                    "name": "Sorting",
                    "type": "local",
                    "caseSensitive": false
                    "columnSettings": [],
                    "name": "Filtering",
                    "type": "local",
                    "caseSensitive": false,
                    "mode": "simple"
                    "columnSettings": [{
                        "columnKey": "SampleId",
                        "required": false,
                        "readOnly": true,
                        "validation": false
                        "columnKey": "PartId",
                        "required": true,
                        "editorType": "combo",
                        "editorOptions": {
                            "valueKey": "PartId",
                            "textKey": "DisplayName",
                            "dataSource": [{
                                "PartId": 1,
                                "DisplayName": "Thigh"
                                "PartId": 2,
                                "DisplayName": "***"
                                "PartId": 3,
                                "DisplayName": "Wing"
                                "PartId": 4,
                                "DisplayName": "Drumette"
                        "validation": false
                    "name": "Updating",
                    "horizontalMoveOnEnter": true,
                    "validation": true,
                    "enableAddRow": false,
                    "enableDeleteRow": false,
                    "editMode": "row",
                    "showDoneCancelButtons": true,
                    "startEditTriggers": "dblclick,f2"
                    "name": "Selection",
                    "mode": "row",
                    "multipleSelection": false
                    "showPageSizeDropDown": true,
                    "name": "Paging",
                    "type": "local",
                    "pageSize": 20
                    "name": "Resizing",
                    "deferredResizing": false
            grid = $("#grid").igGrid(gridOptions);
    </script>
</head>
<body>
    <h1>Grid</h1>
    <div>
        <table id="grid"></table>
    </div>
</body>
</html>
