975
edited text in model is always null
I'm loading up some text from a database into a html editor, making some changes to the text and saving back to the database.  The editor is populated with text, I can change it, but when I save the model back to the controller, the text is always null.  here's how I create the editor
@(Html.Infragistics()
                       .HtmlEditorFor(model => model.MarketCommentary.MarketComment)
                       .Width("600px")
                       .Height("500px")
                       .ID("htmlEditorMarketComment")
                       .ShowCopyPasteToolbar(true)
                       .ShowFormattingToolbar(true)
                       .ShowTextToolbar(true)
                       .Render()
I populate it from an ajax call like this
if ("htmlEditorMarketComment_source" in frm.elements) {
                            $("#htmlEditorMarketComment").igHtmlEditor("setContent", data.MarketComment, "html");
the text is loaded into the editor ok and i can edit it.  I subsequently save the text in the submit event of the form using this javascript code
$('#frmAddMarketCommentary').on('submit', function (e) {
                var $form = $(e.target);
                if ($form.valid()) {
                    e.preventDefault();
                    $.ajax({
                        url: '@Url.Action("Create", "MarketCommentary")',
                        data: $form.serialize(),
                        async: true,
                        type: 'POST',
                        success: function (returnval) {
                            if (returnval.success == true) {
                                // Hide the dialog
                                $form.parents('.bootbox').modal('hide');
                                bootbox.alert('Market Commentary Saved.');
                                $("#marketCommentaryGrid").igGrid("dataBind");
                            if (returnval.success == false) {
                                bootbox.alert({ title: '<div class="text-center text-danger"><i class="fa fa-exclamation-triangle"></i>&nbsp;&nbsp;ERROR</div>', message: returnval['responseText'] });
                        error: function (returnval) {
                            bootbox.alert(returnval['responseText']);
in my controller actionMethod (C#) when I inspect the commentary, its null
item.Commentary  ---- > null
public async Task<ActionResult> Create([Bind(Prefix = "MarketCommentary")]MarketCommentaryViewModel item)
all the other properties have data, its only the one associated with the html editor thats null.  can you help ?
  • 138253
    Hello Mark,
    Thank you for your post. I have been looking into it and I can suggest you first serialize the form and then stringify it using JSON like this:
    var result = JSON.stringify({ 'item': form.serializeArray() });
    then set the result as data to the ajax. Please let me know if this helps you or you need further assistance on this matter.
    Stefan
