35
IGrid events does not work after refreshing Data
I am having issues with events after refreshing datasource, I tried to different ways based on:
https://stackoverflow.com/questions/13294447/reloading-infragistics-grid
https://es.infragistics.com/community/forums/f/ignite-ui-for-javascript/66631/refresh-data-in-grid
I am using a json data model which also has some igCombo columns which are set up on demand
$('#Grid).igGrid('dataBind'); //works refresing grid with current model, but the following events dont work after using this line of code. I also tried creating again the whole grid (without using destroy)
activeRowChanged (grid)
itemsRendered (igCombo column)
selectionChanged (igCombo column)
I also have updating/add/delete features
enableAddRow: true,
enableDeleteRow: true,
editMode: 'row',
None of them work after calling dataBind again, nor creating grid again
$(lGrid").igGrid({
            dataSourceType: 'json',
            dataSource: Details,
            primaryKey: "id",
            featureChooserIconDisplay: "always",
            autoGenerateColumns: false,
            autoGenerateLayouts: false,
            rowVirtualization: true,
            virtualizationMode: "continuous",
            autoCommit: true,
            width: "100%",
            height: "800px",
            columns: columns,
            features: features
  • 530
    Hello cristian,
    Based on the grid configuration provided, I created a sample application. After calling igGrid's dataBind method, the events you mention work on my end. Would you check if the sample works as expected? If additional configuration is required, would you share the information?
    2671.igGrid_combo.zip
