80
Dynamically creating and adding igGrid on poge via ajax call
I have a button which makes an ajax call and gets json data. On success, this data is displayed on an igGrid. Below is the snippet.
Problem: The first time I click the button, no data is displayed. The second time I click it,. the igGrid shows data. Please help.
Below is the code snippet:
$("#button").on('igbuttonclick',
function (e) {
$.ajax({
type: "POST",
contentType: "application/json; charset=utf-8;",
url: "/Home/GetJSON",
dataType: 'json',
success: function (data) {
var json = JSON.parse(data);
//var dataa = [
//{ "Name": "Mark", "Age": 25 },
// { "Name": "Bill", "Age": 59 },
// { "Name": "Tim", "Age": 54 },
//The JSON has multiple tables. I create an igGrid for each table
Object.keys(json).forEach(function (key) {
var tbl = document.createElement("table");
tbl.setAttribute("id",key)
$("#" + key).igGrid({
dataSource:dataa
//Have a div called "resultsView" on the view
$("#resultsView").append(tbl);
error: function (a, b, c) {
alert('Failed');
  • 6365
    Hello Guruprasad,
    In order to fully initialize the igGrid along with its dataSource, you will have to include the newly created table to the DOM tree first and then initialize the igGrid itself with the respective id.
    For example:
     dataSource:dataa
    I have attached a sample application that demonstrates the approach from above by using a button click.
    If you have any questions, please let me know.
    6076.igGridSample.zip
    Sincerely,
    Tacho
    Associate Software Developer
