Hi ,
I'm having an Issue while doing remote Pagination ,
The Following are my requirement
I have used Remote Side pagination For IgGird .
I’m having total 30 records in List ,
While Page Load by default records are loaded in IgGrid and working fine but as per our requirement we need to Display All values by Clicking "ALL" text in paging dropdown .
So I have included a text “All” text to display all records as follows,
pageSizeList: [1, 2, 3, 4, 8, 30, "All"],
My issue is while clicking the text "All" in Paging dropdown , Grid shows all the 30 records but the after that I’m unable to use any other event or navigation within the grid after
choosing the text “ALL” in drop down the text should be "ALL" and I need to access other events in grid.
I have attached a sample source and sample video with this POST your for reference.
Kindly review the source and do the needful.
Note: Kindly run the source from Product.cs page .
Iggrid Paging video.rarProduct.rarIndex.rarHomeController.rar
Hi Nadhakumar,
What do you mean that you're not able to use other event or navigation within the grid after choosing "All" page size from the dropdown? Could you be more specific and provide some steps to reproduce the issue? If you mean that you cannot use remote sorting and remote filtering, you should note that they won't work out of the box when you're using the igGrid jQuery widget. Remote features in igGrid work out of the box with the MVC wrapper. So, please let me know what is your exact concern, so that I can be of further help for you.
Tsanna
I have used Infragistics v16.2 dll.
Kindly find the source code attached for the above post and kindly do the needful .
IgGrid paging.zip
