I follow the sample code and implement excel export successfully. However, I notice it's not working after I publish the code to the server. It says "error processing your request"
Hello nikki,
It would be great if you share some code implementation or working sample with the issue, in order to host it on our environment or at least double check the export functionality that you follow.
If you have any code sharing constrains, let me know in order to make this thread private and share your code there.
Hi Zdravko,
Unfortunately I cannot trace down any other helpful error message with this issue as I tried to debug it. I even used developer tool to see if I spot anything. Because of time constraint, we decided not to use the feature for now. I will come back for further assistance when we revisit this topic. Thank you!
Nikki
Hello Nikki,
Thank you for contacting us.
Is it possible to provide more information about the issue, for example after opening the browser console, what are the error messages or are there any Network messages related to cross-origin restriction for example.
