I need to add couple new header icons next to Pin/Unpin,Restore,Minimize and Maximize icons. Could you please advise how can I achieve it ?
I tried searching on forum , however no luck. Your timely response is highly appreciated.
Thanks Alexander , it worked :)
Hello Chirag,
Thank you for using Ignite UI!
You can achieve your scenario by creating the desired custom buttons and appending them to the dialog’s header. I am attaching a sample with an example of a custom button that calls a custom function when clicked.
I hope this will help you with your scenario!
If anything else pops out – do not hesitate to contact us again!
Thank you once more for using Ignite UI!
Best regards,
Alexander Marinov
