620
Trouble building when using Ignite UI w/ Angular 4 CLI
I am having build issues when using the Ignite UI w/ an Angular 4 app that I created using the Angular CLI.  Here are the steps to reproduce the issue I'm seeing.  These steps assume that you have npm and the angular CLI installed.
1) Using the Angular CLI, create a test app:
     ng new ignite-sample
2) Install this package.
     npm install enhanced-resolve@3.3.0 --save
3) Verify that the build is successful.
     ng build --prod
4) Install the IgniteUI packages
     npm install ignite-ui --save
     npm install igniteui-angular2 --save
5) Add the following imports to update app.module.ts:
     import { IgGridComponent} from 'igniteui-angular2';
     import { IgComboComponent} from 'igniteui-angular2';
     import { IgSplitterComponent} from 'igniteui-angular2';
6) Add the following to the declarations section of app.module.ts:
     IgGridComponent,
     IgComboComponent,
     IgSplitterComponent
7) Run the build again.
     ng build --prod
The build will fail with this error:
ERROR in Type IgGridComponent in C:/temp/ignite-sample/node_modules/igniteui-angular2/index.d.ts is part of the declarations of 2 modules: IgniteUIModule in C:/temp/ignite-sample/node_modules/igniteui-angular2/index.d.ts and AppModule in C:/temp/ignite-sample/src/app/app.module.ts! Please consider moving IgGridComponent in C:/temp/ignite-sample/node_modules/igniteui-angular2/index.d.ts to a higher module that imports IgniteUIModule in C:/temp/ignite-sample/node_modules/igniteui-angular2/index.d.ts and AppModule in C:/temp/ignite-sample/src/app/app.module.ts. You can also create a new NgModule that exports and includes IgGridComponent in C:/temp/ignite-sample/node_modules/igniteui-angular2/index.d.ts then import that NgModule in IgniteUIModule in C:/temp/ignite-sample/node_modules/igniteui-angular2/index.d.ts and AppModule in C:/temp/ignite-sample/src/app/app.module.ts.
I have attached a zipped project.  To reproduce the issue, run these steps:
1) npm install       (to re-hydrate the modules)
2) ng build --prod
Any help that you can provide would be appreciated.
ignite-sample.zip
