8920
PAge designer
Page designer : http://designer.igniteui.com/
When trying to start new it gives warning :
Erase current page?
Starting with a new blank page erases your current page in the Designer. If you want to save your page code, be sure to copy/save it before starting a new page.
Where is the copy/save  option located.. can not find it...  or it is browser save ?
  • 10685
    Verified Answer
    Hello Michael,
    As the warning message implies, the best way to save your work will be to manually copy the generated code and save it in a local file on your machine. If you would like to have all of the generated code for example, including the referenced libraries/resources, you can directly create a new empty html file locally and copy/paste all of the Code pane content. From this point, the local file should be runnable.
    Please let me know how this approach works for you.
    PS: We may consider adding some alternatives for saving the current work at future releases.
