555
Ig Combo box - Multi select - Select All
I am using Ig combo with multi select option with checkboxes in ASP.NET MVC
@(Html.Infragistics()
.Combo()
.ID("Ids")
.MultiSelectionSettings(s => { s.ShowCheckBoxes(true); s.Enabled(true); })
.DataSource(@ViewBag.Ids.Items)
.TextKey("Description")
.ValueKey("ID")
.Width("280px")
 .Render())
Then binding the onChange event like this:
$("#Ids").bind("igcomboselectionchanging", OnIdsSelected);
function OnIdsSelected(evt, ui) {
if(ui.items[0].data.ID == -1)
//Select all checkboxes
I am not sure how to select all the remaining checkboxes in the combo box when the first item is selected.
I tried $("#Ids").igCombo("Items") but this doesn't give me all the items
Can someone please suggest the correct syntax for this?
Regards
Singh
  • 845
    Hello Singh,
    Thank you for contacting Infragistics Developer Support!
    In your case you can use the selectAll method of the combo i.e
    $("#checkboxSelectCombo").bind("igcomboselectionchanging", function(evt, ui) {
      if (!ui.currentItems && ui.items && ui.items[0].data.ID === -1) {
         ui.owner.selectAll();
         return false;
    However you would have to cancel the selectionChanging event. A better approach is to use a header template where you can place a button/checkbox/etc and call the selectAll method through the igCombo API.
    For more information check: this and this and a sample showing off the header template feature
