45
First td tag of single column template is deleted
I have a grid in responsive mode with a single column template that contain a table.
I use jsRender for the template engine.
During the execute template, i lose the first "<td" and the first "</td>".
This break the HTML of my template.
This replace is done in the _executeTemplate of the infragistics.lob.js :
_executeTemplate: function (data) {
   if (this._jsr) {
      return $.render[ this.grid.id() + "_responsiveSct_" + this._mode ](data)
      .replace("<td", "").replace("</td>", "");
   return $.ig.tmpl(this.options.singleColumnTemplate[ this._mode ], data)
I reproduce the problem in this example : http://jsfiddle.net/yuz7LwLa/2/
Is there a way to avoid the replace?
Thank.
Yoann
  • 25665
    Verified Answer
    Hello Yoann,
    I have done some looking into this matter and you shouldn’t use a table in the template. It will very likely cause you performance issues as for each row it will render an additional table when the grid is already a table. Instead you should use div, span elements and CSS to template how you want it to appear.
