hi, i try to create cascade combos but i cant AddClientEvent to ComboEditorOptions here my code
@(Html.Infragistics() .Grid(Model.Pisos) .ID("grdMenu") .LoadOnDemand(false) .AutoGenerateColumns(false) .PrimaryKey("IdPiso") .AutoGenerateLayouts(false) .AutoCommit(true) .Columns(cols => { cols.For(x => x.IdPiso).Width("25%").HeaderText("Level"); cols.For(x => x.DescPiso).Width("25%").HeaderText("Description"); cols.For(x => x.IdTypeComposition).Width("25%").HeaderText("TypeComposition").FormatterFunction("lookupType"); cols.For(x => x.IdFormato).Width("25%").HeaderText("UPCFormat").FormatterFunction("lookupUPC"); //cols.For(x => x.FormatoUPC).Width("25%").HeaderText("UPCFormat"); cols.For(x => x.Bunches).Width("25%").HeaderText("Bunches"); }) .ColumnLayouts(layouts => { layouts.For(x => x.Composition) .PrimaryKey("IdProduct") .ForeignKey("IdPiso") .AutoGenerateColumns(false) .Features(feature => { feature.MultiColumnHeaders(); }) .Columns(childcols1 => { childcols1.MultiColumnHeader().HeaderText("Composition").Group(c => { c.For(x => x.Product).HeaderText("Product"); c.For(x => x.Variety).HeaderText("Variety"); c.For(x => x.Grade).HeaderText("Grade"); c.For(x => x.Stems).HeaderText("Stems"); }); }); layouts.For(x => x.Material) .PrimaryKey("IdMaterial") .ForeignKey("IdPiso") .AutoGenerateColumns(false) .Features(feature => { feature.MultiColumnHeaders(); feature.Updating() .AddRowLabel("New Level") .AddClientEvent("selectionChanged", "EditCell") .ColumnSettings(settings => { settings.ColumnSetting().ColumnKey("Tipo").EditorType(ColumnEditorType.Combo).Required(true).ComboEditorOptions(co => co.ID("grdcbTipo").DataSource("/NewFinalProd/getMaterial").ValueKey("codsub").TextKey("nomsub").Mode(ComboMode.DropDown).EnableClearButton(false).AddClientEvent("selectionChanged", "loadDescription")); settings.ColumnSetting().ColumnKey("Description").EditorType(ColumnEditorType.Combo).Required(true).ComboEditorOptions(co => co.ID("grdcbMaterial").DataSource("/NewFinalProd/getMaterial").ValueKey("codsub").TextKey("nomsub").Mode(ComboMode.DropDown).EnableClearButton(false)); }) .EnableAddRow(true) .EnableDeleteRow(false) .EditMode(GridEditMode.Row) .ShowReadonlyEditors(false); }) .Columns(childcols2 => { childcols2.MultiColumnHeader().HeaderText("Material").Group(c => { c.For(x => x.Tipo).HeaderText("Type"); c.For(x => x.Descripcion).HeaderText("Description"); c.For(x => x.Cantidad).HeaderText("Quantity"); }); });
}) .Features(feature => { feature.MultiColumnHeaders(); feature.Updating() .AddRowLabel("New Level") .AddClientEvent("editRowEnded", "bridgeEditRow") .ColumnSettings(settings => { settings.ColumnSetting().ColumnKey("IdPiso").ReadOnly(true); settings.ColumnSetting().ColumnKey("IdTypeComposition").EditorType(ColumnEditorType.Combo).Required(true).ComboEditorOptions(co => co.DataSource(ViewBag.lstType).ValueKey("IdTypeComposition").TextKey("NameCoposition").Mode(ComboMode.DropDown).EnableClearButton(false)); settings.ColumnSetting().ColumnKey("IdFormato").EditorType(ColumnEditorType.Combo).Required(true).ComboEditorOptions(co => co.DataSource(ViewBag.lstUPC).ValueKey("IDFormato").TextKey("Formato").Mode(ComboMode.DropDown).EnableClearButton(false)); }) .EnableAddRow(true) .EnableDeleteRow(false) .EditMode(GridEditMode.Row) .ShowReadonlyEditors(false); }) .Width("100%") .DataSourceUrl(Url.Action("GetFinalproductPisosByIdFinalProd")) .DataBind().Render())
Glad I could help. If you need further assistance with this, please let me know.
Hi Michael,
thanks a lot for your help , i will try this options.
Hi Jorge,
Each child grid is its own instance of an igGrid. You can access them using the allChildrenWidgets method. This would require the children to be populated and rendered first, so you may need to handle the childGridRendered event, which even provides the childgrid object in the arguments.
Other than that, you could also send the lookup data in its own object so you do not need to search through the datasource like that.
If you have any further questions or concerns with this, please let me know.
Hi again,
i need know how create de lookup tables, in the iggrid i use this:
var TypeLookup = [], UPCLookup = [], loadingIndicator; $(function () { var grid = $("#grdMenuE"), comboDataSource = {}; comboDataSource = grid.data("igGridUpdating").options.columnSettings[1].editorOptions.dataSource; for (var i = 0; i < comboDataSource.length; i++) { TypeLookup[comboDataSource[i].IdTypeComposition] = comboDataSource[i]; } comboDataSource = grid.data("igGridUpdating").options.columnSettings[2].editorOptions.dataSource; for (var i = 0; i < comboDataSource.length; i++) { UPCLookup[comboDataSource[i].IDFormato] = comboDataSource[i]; } });
function lookupType(id) { return TypeLookup[id].NameCoposition; }
but i don't know hou access the editors from de igHierarhcicalGrid, the data comes from the database a c# list<t>.
The formatter function can be set on each column in the column collection like in the igGrid.
Are you asking specifically how you would create the lookup tables for the igHierarhcicalGrid?
There are many options available for this. You could send down a separate JSON object to keep track of the values. I do not know how your data is formatted, so I cannot provide any specific information.
If I am misunderstanding your question, please try to clarify for me.
