Whenever I enable minification by using the UglifyJsPlugin for webpack, I get following error.
"Template parse errors: Can't bind to 'dataSource' since it isn't a known property of 'ig-grid'. 1. If 'ig-grid' is an Angular component and it has 'dataSource' input, then verify that it is part of this module. 2. If 'ig-grid' is a Web Component then add "CUSTOM_ELEMENTS_SCHEMA" to the '@NgModule.schemas' of this component to suppress this message. (" <div> <ig-grid widgetId="grid1" [ERROR ->][dataSource]="mydata"></ig-grid> </div>' "): t@2:26 'ig-grid' is not a known element: 1. If 'ig-grid' is an Angular component, then verify that it is part of this module. 2. If 'ig-grid' is a Web Component then add "CUSTOM_ELEMENTS_SCHEMA" to the '@NgModule.schemas' of this component to suppress this message. (" <div> [ERROR ->]<ig-grid widgetId="grid1" [dataSource]="mydata"></ig-grid> </div>' "): t@2:0"
If I don't use the UglifyJsPlugin, everything works fine.
I've attached a sample app to demonstrate this behaviour.
I started from https://github.com/angularclass/angular2-webpack-starter.git, integrated 'igniteui-angular2' and enabled the UglifyJsPlugin in de webpack dev config.
Steps to reproduce:
1. npm install
2. npm start
Please advise on how to solve this.
Thanks!
This sounds like a third party issue. And I found more info on it here.
So include keep_fnames to the mangle of the Uglify:
mangle: { screw_ie8: true, keep_fnames: true },
Also make sure you have declared you data initially:
public mydata: any = [];
