600
Angular2 igCombo input text disappears after dataSource changed (rebind) at runtime
the igCombo input text disappears when the dataSource was changed at runtime. After every keystroke i call the search engine to get the new result data based on the current input text and then i rebind the igCombo. The valueKey and textKey stays the same. The "allowCustomValue" option is set to TRUE. The expected behavior is that the input text should remain after a rebind if this option is set. The goal is a auto complete search with suggestions like google. Every search request take approximately 20 - 40 milliseconds to finish. The dataSource will be set in the view directly => [(dataSource)]="comboDataSource".
This are my options:
this.comboOptions = {
            valueKey: 'recordId',
            textKey: 'recordName',
            autoComplete: true,
            virtualization: true,
            visibleItemsCount: 5,
            allowCustomValue: true,
            autoSelectFirstMatch: false,
            width: '100%'
Is it a bug or is it a wrong usage?
