40
Unit testing IgGrid component with Angular2
Hi
I am using igGrid to build a Angular2 component, I believe IgGrid is developed using JQuery, instead Angular2 but it can be used with Angular2.
Now if I write unit test cases for the component then won't it load jQuery & igGrid components internally?
Also can somebody please share some sample code how can I write unit test cases for the component which uses igGrid in Angular2?
Atul Sureka
  • 3995
    Hello Atul,
    Thank you for posting into Infragistics community!
    The components are not loading jQuery and igGrid internally, you need to handle this.
    Angular2 repo has a set of tests for all of the widgets, including the igGrid. Here's a link to the igGrid ones.
    Also you can review the karma config file to how the scripts are loaded.
