750
Allow CTRL + SCROLLWHEEL to change page zoom.
I would like to be able to change the page zoom using the CTRL key in combination with the mouse wheel. If the mouse hovers over an igGrid which has a vertical scrollbar, then the grid scrolls instead (as if the CTRL key was not pressed). Only when the grid scrollbar reaches the top/bottom the page starts zooming.
I'm seeing this behavior with version 16.2.20162.2040. (I did not see this behavior with version 15.1.20151.2352)
Here is an example:
http://www.igniteui.com/grid/datatable-binding
  • 23953
    Hello Robin,
    We've logged an internal issue with Development ID 230823 to investigate this behavior.
    I also created a case on your behalf with number CAS-180319-K1W6P7, so that you can be notified when there is a resolution for the issue.
    You can find your active cases under Account - Support Activity in our website. Select your ticket and go to Development Issues tab to view the status of related development issues.
    Best regards,
    Martin Pavlov
    Infragistics, Inc.
