Hi All,
Recently i have downloaded the PM Dashboard solution from http://www.igniteui.com/application-samples
When i opened the solution, i am getting following error message and also attached current visual studio version screen shot.
In VSIXPM-Dashboard.csproj
<UsingTask AssemblyFile="E:\Work\2\1057\bin\Release\ProjectTemplatesBuildTasks.dll" TaskName="ProjectTemplateGen" /> <Target Name="BeforeBuild"> <ProjectTemplateGen ProjectFullFileName="$(MSBuildThisFileDirectory)..\PM-Dashboard\PM-Dashboard.csproj" ProjectDir="$(MSBuildThisFileDirectory)..\PM-Dashboard\" ProjectNamespace="PM-Dashboard" TemplateFileFullPath="$(MSBuildThisFileDirectory)\PMDashboard.vstemplate" DestinationRoot="$(MSBuildThisFileDirectory)ProjectTemplates\CSharp\Infragistics\Ignite UI" NameOfZipFile="PMDashboard.zip" IconFileFullPath="$(MSBuildThisFileDirectory)\PMDashboard.ico" PreviewImageFullPath="$(MSBuildThisFileDirectory)\PMDashboard.png" /> </Target>
Okay.
Yes Tihomir,
I need to download the VS2015. Once downloaded , i will test it and update to you.
Hello Mohan,
I am looking forward to hearing from you if you have any questions.
Thanks Tihomir. I will check and update if any queries.
Thank you for contacting us.
This project is compatible with Visual Studio 2015.
Fortunately this project is not needed for the application sample to run correctly. Run the PM-Dashboard project and the application will run correctly.
Please let me know if you need further assistance.
