Hi There,
I'm using the Tree Grid to display some recursive hierarchical data, but the Selection API doesn't appear to work when selecting the nested rows.
Can you please give me an example of this working? I actually need the DATA of the selected row.
The documentation doesn't go in to this as its inherited from the igGrid and this doesn't deal with hierarchical data.
My grid code:
$("#treeGrid").igTreeGrid({ width: "100%", height: w, dataSource: data, dataSourceType: 'json', autoGenerateColumns: false, columns: [ { key: "name", headerText: "Name", dataType: "string", width: 550, template: "<span> <img src='${iconPath}' /> ${name} </span>" }, { key: "weight", headerText: "Weight", dataType: "string" },{ key: "ccy", headerText: "CCY", dataType: "string" }, { key: "type", headerText: "Type", dataType: "string" },
//Leave this in... it doesn't render the icon in the template if the path isn't bound to something { key: "iconPath", headerText: "Icon", dataType: "string", hidden: true }, { key: "id", headerText: "Id", dataType: "string", hidden: true }, ], childDataKey: 'constituents', renderExpandColumn: true, initialExpandDepth: 0, features: [ { name: "Selection", multipleSelection: false, activation: true, rowSelectionChanged: function (evt, ui) {
//nothing in this method, or any inspection of the objects reveals any way to get the data of the selected nested row
var grid = $('#treeGrid'); var row = $('#treeGrid').igTreeGrid('selectedRow'); var activeRow = $('#treeGrid').igTreeGrid('activeRow'); var data = $('#treeGrid').data('igTreeGrid').dataSource.dataView(); var dataRow1 = ui.row.element.data; var dataRow = ui.row.element.data();
var selectedData = data[row.index];
Many thanks,
Matt
Hey Matt,
Great job! I'm glad to hear that.
Excellent thanks, that works a lot better.
The data returned is not the same object reference as the data in the original array, but I maintain a parent_id on the children, so I only need to loop over the top level items to find the data record I require, so far more efficient.
Thanks for the prompt help!
Hello Matt,
Yes, that's right the selection is not going to store the whole data record, so extracting information for a nested record in a huge data might be trouble.
Have you tried using findRecordByKey API method? Here's an updated fiddle.
Does this method still locks the UI with your data?
Thanks, turns out I hadn't set the primary key, hence the reason the ID's didn't correspond.
Its still not quite perfect though, as I still have to recursively loop through my data set each time to find the data item with the selected ID.
Is there a cleaner way to call the Grid for the selected Data?
If I have a data set of a couple of thousand rows with multiple levels of nesting, just selecting a nested row could be very expensive and lock the UI.
Thank you for posting into our community!
Actually the ui.row parameter is returning the information you require.
Here's a fiddle to demonstrate this, please let me know if it helps.
