I am using igGrid where my columns are creating dynamically on product selection(column data from database). Even the cell will have dropdown or text box that info is also dynamic as per user selection.
I want to have a grid which is editable (on edit mode must have textbox or combo box as per the data) and user doesnot have to click on Done button on each edit.
I tried achieving this by hiding Done container but when I programmatically add a new row then I need the new row to be editable without done but...and getting error : already a row is in edit mode
By design igGrid can have only one row or cell in edit mode at a time. As each such row or cell uses full-fledged Ignite UI editors, having all cells constantly in edit mode will be very costly from a performance standpoint. The Done and Cancel buttons are purely optional and Updating can operate without them using only the keyboard to submit or cancel changes.
By default editing starts on a single click. You probably have to click twice because there is also Selection enabled and the two need different clicks to be able to work separately. You could circumvent this by binding to e.g. rowSelectionChanged and start editing programmatically with the startEdit function.
About the validation - I'll need to see how you are trying to accomplish it but seeing you are already using saveChanges, I'd suggest doing the server-side validation with it as opposed to triggering it on each text/value changed editor event. Basically, you have to keep autoCommit disabled (the default state), and then on each editRowEnded you call saveChanges with a success and error callbacks (the first and second parameters of the function). On success you execute a manual commit and on failure you can display an error to the end-users that something went wrong with verifying their input and optionally rollback. You can find out more about persisting changes server-side from this help topic.
I don't think I understand the use-case described in c). Is the behavior reproducible in the sample you are going to attach?
Best regards,
Stamen Stoychev
I will attach some code with my next reply.
Few of my requirement are listed below so that I can give you a better understanding of what I want:
a) A grid which is editable (can I have one in which each row is editable(user dont need to double click to get into edit mode) without Done and cancel button.)
b) And each element when value or text changed should be validated from database.Can I specifically bind an error message against a cell.JQuery is an option but just want to confirm without that. Validation option is not working as expected at my end. Required feature works fine.
c) And also regarding Row selectors End Edit and Start Edit is taking time to execute so if user selects any row complete grid row cells gets a selector and checkbox.
Could you please attach the sample you are working on or an isolated one reproducing the listed issues? I created a case on your behalf with #CAS-179270-N7X4J7 that you can use to send it privately. To view your cases, go to our Website > Account > Support Activity.
Thank you in advance!
Also I am facing one more issue...even when my Done button is there .. When a row clicked for edit all the dropdowns are getting set to the first index value.
e.g. if in my Row I have a drop down with options "Red","blue","Black".
I selected black and Saved it. Again I double click on the row to edit The value in drop down is getting set to "Red"- The first value.
Is there any settings in editor options which I am missing??
Hi Stamen,
Thanks for all your help.
I already tried : $(grid).igGridUpdating("endEdit", true, true);
but getting error that $rootscope.$apply() is already in progress.
AutoCommit is also true
