Simple numeric editor.. while turning readOnly to true, how to make it visually disabled.. thanks
<input id="auEnd" style="font-size: 16px; font-weight: bold " /> <label class="auSpan">
$("#auEnd").igNumericEditor({ dataMode: "int" , groupSeparator: '' , value: null , minValue: 2000 , maxValue: new Date().getFullYear() + 10 , button: "spin" , width: 90 , height: 30 , valueChanged: function (evt, ui) { auditVM.OneAuditData.AuditPeriodEnds(ui.value); } });
Hello Michael,
Thank you for using our community.
The readOnly property of our igEditor controls don’t change the visual appearance of the editor itself. Depending on your scenario if you want to visually disable the input you can either use the disabled property or you can add a custom class to the component and apply custom CSS. In the following sample you can see both suggestions implemented:
http://jsfiddle.net/qggz33wp/
Please let me know if I can be of further assistance.
Best Regards, Marina Stoyanova, Software Developer, Infragistics, Inc.
