I am using IGGrid in an angularJS project, I am creating an angularJS grid in the controller and using default gird.igGrid() method to create the grid. However when I try to sort the column, few random columns get highlighted on sort.
Can anyone help me with isolating the issue.
Okay thank you
Hello Hamza,
Thank you for the update. You can set the applySortedColumnCss property to false to disable that behavior:
http://www.igniteui.com/help/api/2016.2/ui.iggridsorting#options:applySortedColumnCss
yes, I mean once I sort a particular column, yes the column other than I sorted get highlighted. I am currently using angular 1.5.2. I currently don't have a sample project. Is there any way that I can disable column highlighting all together for sorting ?
When you say a few random columns get highlighted, do you mean columns other than the column you sorted are being highlighted? What version of Angular are you using?Do you have a sample project?
