Hi Team
Goto Data Visualization and add the Map control. After adding the control I'm unable to remove the control like other controls (textbox,grid).
when i right click "Remove Component" option is not available . Alternatively i used Delete button.
If its a bug kindly fix it.
Karthikeyan Rajakumar
This is the information I am looking for. This article is clear and easy to understand. I'm learning more about this. Hope you bring more things related to it. Thanks a lot!
html color
Hello Karthikeyan Rajakumar,
Thank you for posting in our forum!
I have tested this using the steps you have specified and could not reproduce the issue. It was successfully removing the map widget from both Design and Code panes.
Notice the designer is currently targeting Chrome browser, so it should be used for best user experience.
In case there are more steps involved in reproducing the issue, or in the environment please feel free to share.
