Hi All,
I need to bind a combo box in infragistics grid on button click.I am not able to see the combo box on grid binding.I want to know why I am not able to do so.Please help.Thanks
Hello:
I'm try to generate the combobox data source from taked it from columnsetting of the grid, like: comboRightsDataSource = grid.data("igGridUpdating").options.columnSettings[2].editorOptions.dataSource;But It's not working for me because I need to take from hierarchy grid and I have the combobox on the columns layout. Do you have any idea how to take it?
This line of code should execute when you are on button click method and you should get your grid by correct id. If your approach is like that I'm describing please send me the isolated working sample to see what exactly is the problem.
I'm looking forward your reply.
Yes Of Course I am changing the with my column key from the Grid
EditorForKey (Gets the editor for a column by the column key). I want to clarify that you change the string ("your field name") with your column key from the grid.
Thanks for the reply,but when I am using ("#grid").igGridUpdating("editorForKey", "Your field name").data().igCombo.I am getting the data as null on button click.Can u tell me the what is the editorForKey property?
