45
ToolTip Related
I am using
public func chartView(chartView: IGChartView, tapForSeries series: IGSeries, withItem item: NSObject, atPoint point: CGPoint)
to add my custom lable to show tooltip value by adding subview on chartview but I want to remove tooltipview  when user tap other than tip point I have added a tap gesture but it did not solve my problem.
  • 2095
    Hello virendra kumar,
    Thank you for posting in our community!
    I would like to ask you for more information about your case. Provided example will be appreciated with code comments on the right spots. Also I would like to ask you to  systematize the details of your scenario and provided it in understandable way. It will be good if you use some "steps to reproduce" approach:
    Description: Some general info about the issue
    Steps to reproduce:
    1. what to do 1st
    2. what to do after that
    3. what to do last
    Actual result: Something happens.
    Expected result: I expected to happen something different.
    The better the scenario is described, the better we will understand it and will provide a solution.
  • 45
    Please help me
