I am building the grid ui and looking for the following sample :
Grid that has one column editor as a drop down that is a grid template..
Thanks.
Does grid as an editor is supported as e.g. combo ( editorType: 'combo' ) ?
I rather see the following ui schema main grid --> drop down grid in one column --> one column of that grid has combo that allows to set up values.. do not see as drop down grid can be substituted by combo..
Hello Michel,
I like the suggestions given by Steve. I would say to get combo in the grid itself refer following sample and to bind combo as a grid try creating alternative row template using the templating engine. As following .
http://www.igniteui.com/combo/grid-with-combo-editor
http://www.igniteui.com/help/creating-an-alternating-rows-template-(igtemplating)#creating-alternative-row-template
Please let me know if I may be further assistance.
I think you might want to try using the template engine(Here is an example of creating a table template):
That is close.. but I rather looking for the case with actual grid as template, so it drops down and user see the grid ..
Something like image attached ...
