1010
How to set the data on a tree grid through ajax call?
I am creating a treegrid, and then afterwards populating it with flat data that has primaryKey-foreignKey relationship.
Initially I was using JSONDataSource, but that caused the data to be flat.
Not I am using TreeHierarchicalDataSource, but I get an error when I try to set the dataSource on the treegrid. I tried creating a schema, but still get the same error.
Can you please advise?
Thank you!
The Tree Grid and the ajax call:
$("#tree-grid").igTreeGrid({
    updateUrl: saveDataRowUrl,
    //dataSourceType: "json",
    autoGenerateColumns: false,
    autofitLastColumn: false,
    primaryKey: "PrimaryKey",
    foreignKey: "ParentId",
    foreignKeyRootValue: "0_0",
    initialExpandDepth: 0,
    enableHoverStyles: true,
    autoCommit: false,
    fixedHeaders: true,
    renderExpansionIndicatorColumn: true,
    columns: gridOptions.getColumns(),
    features: [
            type: "local",
            mode: "simple"
            type: "local",
            mode: "single",
            columnSettings: gridOptions.getSortingColumnSettings()
            enableAddRow: false,
            enableDeleteRow: false,
            enableAddChild: false,
            editMode: "cell",
            horizontalMoveOnEnter: true,
            columnSettings: gridOptions.getUpdatingColumnSettings()
            enableRowNumbering: false
            mode: "cell",
            multipleSelection: false,
            activation: true
    rendered: function (evt, ui) {
        otcQuotePageOptions.getQuoteDataRows("#tree-grid", guid);
function getQuoteDataRows(selector, guid) {
    $.ajax({
        url: "Home/GetDataRows",
        cache: false,
        type: "post",
        data: { "guid": guid }
    .done(function (jsonData) {
        var schema = getDataRowSchema();
        var datasource = new $.ig.TreeHierarchicalDataSource({
            type: "json",
            data: jsonData,
            schema: schema,
            treeDS: {
        $(selector).igTreeGrid("option", "dataSource", datasource);
        $(selector).igTreeGrid("dataBind");
    .fail(function (xhr, ajaxOptions, errorThrown) {
        console.error("Response: " + xhr.responseText);
        console.error("Status: " + xhr.status);
        console.error(errorThrown);
The error message:
infragistics.core.js:264 Uncaught Error: There was an error parsing the JSON data and applying the defined data schema: Cannot read property 'Metadata' of null
