60
Bringing "this" into scope for the formatLabel function
I'm trying to create a formatLabel function that can reach "this" in typescript.
This populates the labels with the correct date, but i need to reach a variable in the class to check the resolution so i can format the date accordingly.
formatLabel: function (value) {
   var d = new Date(value.Time);
   return d.getDate() + "/" + (d.getMonth()+1);
When i do this i successfully trigger the desired method and generate the correct string based on the resolution, but it fails to populate the labels in the chart.
formatLabel: ((value) => { this.formatSeriesLabel(value) })
formatSeriesLabel(value) {
   switch (this.dataSource.Resolution) {
      case 7:
         return d.getHours().toString();
      case 20:
         return d.getDate() + "/" + (d.getMonth() + 1);
Changing the method to just return a test string does not return properly either.
formatSeriesLabel(value){
   return "test";
Why isn't this populating the labels in the chart?
