An exception is being thrown while selecting different rows :
The code from 16-1.lob :
_selectionToggle: function (element, dontToggle) { var sel = this.grid.element.data("igGridSelection"); if (!sel) { return; } sel._suspend = !sel._suspend; if (element || dontToggle) { this._actElement = element; } else { this._actElement.focus(); } },
The bug, IMHO, is that the state of the grid while entering the method is not good enough to process. Here are the states of the different variables :
this._actElement === undefined-> truedontToggle-> undefinedelement-> null
The error message and stack trace are :
Uncaught TypeError: Cannot read property 'focus' of undefined(…)
(anonymous function) @ VM1908:1
InjectedScript._evaluateOn @ (program):145
InjectedScript._evaluateAndWrap @ (program):137
InjectedScript.evaluateOnCallFrame @ (program):151
$.widget._selectionToggle @ infragistics.lob-16.1.js:69400
(anonymous function) @ jquery-ui-1.10.3.js:401
$.widget._endEdit @ infragistics.lob-16.1.js:68700
$.widget._mouseDown @ infragistics.lob-16.1.js:67923
proxy @ jquery-1.9.1.js:818jQuery.event.dispatch @ jquery-1.9.1.js:3074
elemData.handle @ jquery-1.9.1.js:2750
this._actElement
The previous version has a bug. This is my latest patch which uses internally the girds own public API which does the job. Here is the modification to the _mouseDown method :
_mouseDown: function (evt) {
if (this.isEditing()) { // can be uncommented for blocking done/cancel buttons //if (this.options.editMode === "cell" || !this.options.showDoneCancelButtons) { // close editing if the end-user clicked somewhere else // this will re-enable selection and allow for subsequent start edit which is // at this point blocked indefinately because of the inability to select anything if (!target.hasClass(this.css.editingCell) && (this.options.editMode === "cell" || this._getRowId(target.closest("tr")) !== this._editingForRowId)) {
// Here is the little modification which checks if we are in dialog mode.
if (this.options.editMode === "dialog") { this.endEdit(false, true); } else { this._endEdit(evt, true, false); } } //} }
Hello Ognyan,
Thank you for getting back to me.
Please let me know if I could be of any further assistance.
