115
Init empty Grid by MVC Wrapper
Hi!
I tried to migrate an ASP.Net MVC project from 2015.2 to 2016.1.
I initialize my controls by the MVC wrapper, because its very easy.
I don't set a DataSource or DataSourceUrl, because in the most cases i set them dynamically in JavaScript afterwards (for example i add a url-get-parameter in reference to an other object).
This behaviour is no more possible in 2016.1. I always get an exception with undefined or null property "Records".
You can test this by your sample project. Just remove the line with "DataSourceUrl" in "Views\Grid\aspnet-mvc-helper.cshtml" and call the page in your browser.
In 2015.2 you get an empty Grid, in 2016.1 you'll get an exception.
It would be great if you can give me a workaround to use them.
I also would like to see an alternative for sending a parameter in the databind-method to the controller by adding a get-parameter to the DataSourceUrl.
