140
NumericEditor with validatorOptions
I have a numericeditor in mvc code as:
It's ok with:
$('#numtest).igNumericEditor({
value: "0",
validatorOptions: {
onblur: true,
required: true,
custom: function (value, opt) { return (value > 0);}
but didn't work:
@Html.Infragistics.NumericEditor("numtest", "numtest", 0).ValidatorOptions(Sub(o)
    o.OnBlur(True)
    o.Required(True)
    o.Custom("function (value, opt) { return (value > 0);}", "Value must be greater than zero")
End Sub).Render
What is syntax for o.Custom("???", "error msg")?
  • 2895
    Verified Answer
    Hello Quan,
    Thank you for using our community.
    The syntax of the custom option is as follows:
    @(Html.Infragistics().NumericEditor()
           .ID("numericEditor")
           .Value("0")
           .ValidatorOptions(x=>
                  x.OnBlur(true)
                  .Required(true)
                  .Custom("validate", "Value must be greater than zero"))
           .Render())
    <script>
           function validate(value) {
                  return (value > 0);
    </script>
    If you need further assistance, don’t hesitate to contact me.
    Best Regards,
    Marina Stoyanova,
    Software Developer,
    Infragistics, Inc.
