How can I use gTree with localStorage to save the opening of the hierarchy ?
Thanks pour for you help.
Damien
Thanks a lot Marina, This sample will help me a lot
Best Regards,
I have updated the sample to correspond to your requirements. The main idea is that you need to store in the localStorage something that identifies the node. And then on reload/refresh of the page to use the expand method from our API and expand the saved nodes. Please try my sample and if you have questions let me know.
Best Regards, Marina Stoyanova, Software Developer, Infragistics, Inc.
Thanks Marina pour your help.
rather, I wish that unfolded nodes is kept in the browser refresh, I hope I express myself clearly.
Thanks you.
Hello Damien,
Thank you for contacting us.
If I understand you correctly, you would like to save the expanded node on expanding? To achieve such a functionality, you can use the NodeExpanded event and in the handler you can save the particular node like this:
nodeExpanded: function(evt, ui) {
if (typeof(Storage) !== "undefined") {
// Code for localStorage.
var node = ui.node;
//save
localStorage.setItem("key", JSON.stringify(node));
//retrieve
var savedNode = localStorage.getItem("key");
savedNode = JSON.parse(savedNode);
//saved node
$("#localStore").html(savedNode.data.RegionName);
} else {
// Sorry! No Web Storage support..
alert("No localStorage support!");
Here is a corresponding sample. Please take a look at it and let me know if you have further questions.
http://jsfiddle.net/h1xeu8th/14/
