I am populating an HTML5 igDataChart that has 5 series which appears to be working fine. Now I am attempting to Clear the chart of the data. I tried using something like this:
$("#chart").igDataChart("notifyClearItem", currDataSource);
But does not work.
Here is how I create the data. Every second I check for data and update. That code sample is below:
data[data.length] = createNewChartItem(data[data.length - 1].Label + 1, v1, v2, v3, v4);
$("#chart").igDataChart("notifyInsertItem", dataSource, data.length - 1, data[data.length - 1]);
function createNewChartItem(label, newvalue1, newvalue2, newvalue3, newvalue4, newvalue5) {
return { Label: label, ValueArcStability: newvalue1, ValueOxygenFlow: newvalue2, ValueCarbonFlow: newvalue3, ValueKWH: newvalue4, ValueRoofOpen: newvalue5 };
My Chart HTML:
$("#chart").igDataChart({
width: "1500px",
height: "750px",
title: "Arc Stability",
// subtitle: "Five largest projected populations for 2015",
legend: { element: "legend" },
windowResponse: "immediate",
dataSource: currDataSource,
axes: [
type: "categoryX",
title: "Sample Number",
label: "Label"
type: "numericY",
minimumValue: 0,
maximumValue: 1000,
title: "Memory Share Value"
series: [
showTooltip: true,
type: "line",
isHighlightingEnabled: true,
isTransitionInEnabled: true,
xAxis: "xAxis",
yAxis: "yAxis",
valueMemberPath: "ValueArcStability",
transitionDuration: 500,
thickness: 3.9,
brush: "orange"
title: "Oxygen Flow",
valueMemberPath: "ValueOxygenFlow",
thickness: 5.9,
brush: "purple"
title: "Carbon Inj Sec.",
valueMemberPath: "ValueCarbonFlow",
thickness: 1.9,
brush: "red"
title: "KWH",
valueMemberPath: "ValueKWH",
thickness: 0.9,
brush: "green"
title: "Roof Open",
valueMemberPath: "ValueRoofOpen",
brush: "black"
Hello Alan,
I have created a private case for you (CAS-171372-L5N6J0) in order not to share your private information in our community, you can attach your app to your reply .Please keep in mind that our system accepts only zipped files.
The app is fully functional in the Node.JS environment and runs well. Just cannot get the chart to display the data after I stop it and flush the chart. The data is present and the Socket.IO code is working fine. I can zip up my test app and send to you. Do you have an FTP or something I can upload to?
Thanks again,
Alan
I checked the provided sample and as I see you are trying to implement client-server Socket.IO example, with sockets and adding data on some interval. The data is not added because your logic is not implemented correctly. You should use node.js in order to make a server listen in particular port (as its shown here http://socket.io/get-started/chat/ ).
Helpful references:
http://stackoverflow.com/questions/11498508/socket-emit-vs-socket-send
http://stackoverflow.com/questions/9914816/what-is-an-example-of-the-simplest-possible-socket-io-example
Here is the jsfiddle:
https://jsfiddle.net/thebigshaboozey/hnkqsf0k/
I hope this helps.
For consistency and readability could you please place your code in jsfiddle example or create .html file. This would help a lot for the investigation and also will be more clear what exactly you are trying to implement.
Thanks in advance.
