1145
sorting on a column containing formatted numbers e.g currency
What is the recommended approach to sorting columns within igGrid, whose value is numerical but has already been converted into a formatted string value.
We have a Quantity field with values such as 99 and 987,654 and 98, when sorted we are getting
99
987,654
98
We would want the sorting to produce
987,654
99
98
Regards
Aidan
  • 23953
    Hello Aidan,
    Sorting respects the column data type. If you provide numericals as strings then they will be sorted as strings. If you want the values sorted as numericals then you need to provide them to the igGrid as numericals and format them in the igGrid column formatter.
    Here is an example:
    var data = [{col1: "99", col2: 99}, {col1: "987,654", col2: 987.654}, {col1: "98", col2: 98}];
    $("#grid1").igGrid({
    	columns: [
    		{ headerText: "col1", key: "col1", dataType: "string", width: "100px"},
    		{ headerText: "col2", key: "col2", dataType: "number", width: "200px", formatter: function (val) {return val.toLocaleString("de");}}
    	dataSource: data,
    	features: [
    Hope this helps,
    Martin Pavlov
    Infragistics, Inc.
