Is there any way to conditionally format an dimension header on the igPivotGrid, ie. change it's background color?
Hello Steven,
You can bind to the igPivotGrid.pivotGridHeadersRendered event and get access to the headers TABLE DOM from where you can apply your formatting logic.
Here is an example:
$("#pivotGrid").on("igpivotgridpivotgridheadersrendered", function(evt, ui) {
ui.table.find("[data-member='0'][data-tuple='1']").css("background-color", "green");
Note: In this case you need to know the data member and data tuple indexes.
Best regards,Martin PavlovInfragistics, Inc.
