Hello,I noticed an error when sorting in a virtualized grid.When enabling Selection and Sorting features there is an error after sorting and unsorting a column when there are other features enabled.It is then impossible to scroll up although there is data above the first visible row.I figured out that this error occurs when either ColumnMoving feature is enabled or Filtering and GroupBy features are enabled at the same time.Please, find a sample attached.In the sample ColumnMoving is enabled. Filtering and GroupBy is commented out.To reproduce do the following:- scroll down to "BBB"- select "BBB"- click on column header "Name" (sort)- shift-click on column header "Name" (unsort)- now it is impossible to scroll upBest regards,Mohamed
Hello Mohamed,
I followed the steps you suggested and was able to reproduce the behavior you're describing.
I investigated your issue, and I have asked our engineering staff to examine this further. To ensure that it will receive attention, I have logged this behavior in our internal tracking system with a Development ID of 213596. The next step will be for a developer to review my investigation and confirm my findings or to offer a fix, or other resolution.
I will leave this case open and update you with any new information after the review. You can also continue to send updates to this case at any time.
You can view the status of the development issue connected to this case by selecting the "Development Issues" tab when viewing this case on the web site.
Please let me know if you need more information.
