I have an editable infragistics grid which has add row , delete row and row updating property set.
I want to disable or make one column read-only so that user does not update it at any cost, when user clicks on Add row. Let the column value be 0 or -1 by default.
How can I achieve this?
2. Is there a possibility to get rid of Done Cancel buttons while editing the grid and enable just inline row editing?
We are using infragistics version - 20132.2364.
Features and grid options configured :
_$calendarImportGrid.igGrid({
height: "310px",
width: "100%",
autoGenerateColumns: false,
alternateRowStyles: false,
virtualization: true,
virtualizationMode: "continuous",
autoCommit: true,
primaryKey: "RowIdentifier",
features: [
enableAddRow: true,
enableDeleteRow: true,
editMode: 'row',
generatePrimaryKeyValue: function (evt, ui) {
ui.value = _getTempKey();
mode: "row",
multipleSelection: false,
activation: true
applySortedColumnCss: false,
columnSorting: function (evt, ui) {
gridHelper.onColumnSorting(_$calendarImportGrid, ui, _initializePlanningCalendarGrid, "RowIdentifier");
return false;
Kiran
Thanks Sam. This helped.
Hello Kiran,
You can make a column read only by setting the readOnly property to true within the columnSettings array of the Updating feature. Here'a link to our API with more info on the readOnly property:
http://help.infragistics.com/jQuery/2015.2/ui.iggridupdating#options:columnSettings.readOnly
You can set a default value by using the rowAdded event and write to the column of the newly added row with the updateRow method. Here's a link to our API with more info on the rowAdded event and updateRow method:
http://help.infragistics.com/jQuery/2015.2/ui.iggridupdating#events:rowAdded
http://help.infragistics.com/jQuery/2015.2/ui.iggridupdating#methods:updateRow
You can remove the done cancel buttons by setting the showDoneCancelButtons property to false. Here's a link to our API with more info on the property:
http://help.infragistics.com/jQuery/2015.2/ui.iggridupdating#options:showDoneCancelButtons
