I'm having some issues with unexpected behaviour of igSelection when using css to over-ride the td of a column when multipleSelection is true.
See this example (also attached)
To demonstrate the unexpected behaviour, start to drag-select in the middle of any of the cells in columns Country or Size. The drag-select acts as expected.
Now drag-select starting from the middle of the cell in population or expire date, and the grid fails to multi select.
However, if you start the drag select from a border in either population or expire date, the multi select works.
How would I get the multi selection to work normally for the columns with the customized background-color?
Hello Michael,
I am glad that you have been able to achieve your requirement.
Please let me know if you need any further assistance with this matter.
I managed to figure out a workaround:
Since the <div> is the thing that is blocking the drag select,
Changing the column template from:
<div class='greenCell'>${ExpireDate}</div>
to
<span class='greenCell'></span>${ExpireDate}
allows the multi selection to work as expected.
