Hi All,
I was working in Infragistics in MVC in which I need to set set height and width of grid dynamically based on record count.Initially height and width of grid is set for 10 records.But when I get 3 records only in the grid the height and width of the grid is not changed according to the no. of records in the grid dynamically.
Plesae find the code given below.
$.ig.loader({
scriptPath: "@Url.Content("~/Content/Scripts")",
cssPath: "@Url.Content("~/Content/css")",
resources: 'igGrid.*',
ready: function () {
$.getJSON("@Url.Content("~/ProviderInquiry/GetAll")", JSON.stringify(dataResponse), function (data) {
var headerTextValues = ["ID", "Suffix", "NPI", "Title", "Address Line1", "Status", "Alpha Sort1", "Alpha Sort2", "Address Line2", "City", "State", "Zip","ProviderInternalNum"];
$('#employeeGrid').igGrid({
expandCollapseAnimations: true,
animationDuration: 1000,
expandTooltip: "Expand to View Details",
collapseTooltip: "Hide details",
height: "35%",
width: "100%",
dataSource: data,
responseDataKey: "Records",
dataSourceType: "json",
autoGenerateLayouts: false,
autoGenerateColumns: false,
rowEditDialogContainment: "owner",
showReadonlyEditors: false,
columns: [
headerText: headerTextValues[0], key: "ProviderID", width: 100,
template: "<a href='@Url.Content("~/Provider/Provider?ProviderInternalNum=${ProviderInternalNum}")' target='_blank'>${ProviderID}</a>"
{ headerText: headerTextValues[1], key: "ProviderSuffix", width: 70 },
{ headerText: headerTextValues[2], key: "NPI", width: 100 },
{ headerText: headerTextValues[3], key: "ProviderTitle", width: 155 },
{ headerText: headerTextValues[4], key: "ProviderAddress1", width: 165 },
{ headerText: headerTextValues[5], key: "ProviderStatus" },
{ headerText: headerTextValues[6], key: "AlphaSort1" },
{ headerText: headerTextValues[7], key: "AlphaSort2" },
{ headerText: headerTextValues[8], key: "ProviderAddress2" },
{ headerText: headerTextValues[9], key: "ProviderCity" },
{ headerText: headerTextValues[10], key: "ProviderState" },
{ headerText: headerTextValues[11], key: "ProviderZipCode" },
{headerText: headerTextValues[12], key: "ProviderInternalNum"}
//{ headerText: headerTextValues[4], key: "UpdateRow", width: 175, template: "<a href='Home/ManageEmployee?EmployeeId=${EmployeeId}&command=edit' class='editDialog'>Edit</a>" },
initialDataBindDepth: -1,
primaryKey: 'ProviderID',
features: [
mode: "row",
multipleSelection: false
//For Hiding columns
columnSettings: [
columnKey: "ProviderInternalNum",
allowHiding: true,
hidden: true
{ columnKey: "ProviderID",
allowHiding: false,
hidden: false
type: 'local',
pageSize: 10,
inherit: true
//Makes a particular column unmovable
columnMovingDialogContainment: "window",
allowMoving: false
//Enable: false
// name: "ColumnFixing",
// fixingDirection: "left",
// columnSettings: [
// columnKey: "ProviderID",
// isFixed: true,
// allowFixing: true
//columnKey: "ProviderTitle",
isGroupBy: true
//Making a particular column nonresizable
allowResizing: false
rowsRendered: function (evt, ui) {
modalMessage = new GridModalMessage(ui.owner);
if (ui.owner.dataSource.dataView().length === 0) {
modalMessage.show("Your search produced no results");
dataRendered: function(evt, ui) {
//To show the Display all records
$("#GridChkbox").show();
Hello Pradeep,
I am glad that you find my suggestion helpful.
I am glad that you have been able to resolve your issue.
Please let me know if you need any further assistance with this matter.
Thanks the issue got fixed and it was working fine.
Could you please try not setting any particular height or width for your grid. In this case igGrid will calculate them internally based on the content available, respectively if you rebind the grid to a data source with more rows igGrid will increase its height according to the new data source. Please try my suggestion on your side. If you are not able to achieve the look and feel of the grid that you are looking for do not hesitate to get back to me with a small, ready to run sample where your issue is reproducible along with steps to reproduce. This is going to be highly appreciated and will help me investigate this further.
I am also attaching a small sample illustrating how igGrid is working when there is no height set and data source is changed - from data source with 6 records to data source with 3. In my sample igGrid recalculates its height correctly.
I hope you find my information helpful.
