Hi Team,
I am generating a grid control using MVC helpers.
I am performing CRUD operations on order. When I search a Order, its Order Items (displayed in Grid) are displayed correctly.
But, when I create a new Order, I want to have the same grid (with no records), just the same structure with a default row and all the buttons inside columns with watermark text present by default so that I can add records to it one by one. Attaching a screenshot about the way I want the grid to be displayed initially while creating Order.
In the screenshot, I need the grid similar to this when I try to create the order (by default a row should be displayed).
I have buttons in the columns. When I click on add new item a new row gets added to the grid with similar structure and so on.
-Regards,
Agraj
Hello Agraj,
Please note that igGrid does not support this way of adding a new row. Here in our samples browser you can get an idea how igGrid Updating feature works: http://www.igniteui.com/grid/basic-editing. If you want to use your approach, I would suggest you to log a product idea at: http://ideas.infragistics.com
Steps to create your idea: 1. Log into the Infragistics Product Idea site at http://ideas.infragistics.com (creating a new login if needed).2. Navigate to the product / platform channel of your choice (e.g. WPF, Windows Forms, ASP.NET, HTML5 / Ignite UI, iOS / NucliOS, etc.)3. Add your product idea and be sure to be specific and provide as much detail as possible. • Explain the context in which a feature would be used, why it is needed, why it can’t be accomplished today, and who would benefit from it. You can even add screenshots to build a stronger case. Remember that for your suggestion to be successful, you need other members of the community to vote for it. Be convincing!• [CASE: “Reference case [case number], FORUMS: “Include a link to this thread”] in your idea so product management will be able to look back at this case.
If I can provide you with further assistance, please let me know.
Tsanna
I would be thankful if you could please raise the priority and help me out with this.
