Hi, I have a problem when I activate the features "RowSelectors" (with enableCheckBoxes = true) and "Responsive". I put the property ui.igGridRowSelectors.rowSelectorColumnWidth but when "Responsive" is enabled, the width is not applied. This column contains only check box, I do not want it adapts automatically. When I turn on igGrid.autofitLastColumn property, it works, but only the last column is adapted. Thanks for your help
If you have more questions on this matter, please let us know.
Thank you for posting into our community.
If autofitLastColumn is disabled and the columns are not filling 100% of the width of the grid, row selectors might be trying to fill the empty space.
So to resolve it you can pick one of the column, which are always in the view (a column which is never hidden by the responsive feature).And remove the width of that column, from column definitions. Just don't set width for it in the columns definitions.
Using this approach that specific column would fill the gap and row selectors should have its width correctly set.
I also recommend removing the width of more columns as possible when using the responsive feature.
