280
IgUpload Get FIle name on error
I have the following code below. I am doing multiple uploads using the control. If anyone of those files should exceed the max upload file size I need to display an error.
"testFileName.txt exceeds max upload size of 15 MB"
Is there an easy way to do this? I have searched the forums and have not found anything. The solution we have come up with is overly complex. I feel like there is a simple solution that we are missing.
  $(document).delegate("#fileNetUpload", "iguploadonerror", function (evt, ui) {
  var filename = "How to get file name"
    if (ui.errorMessage == 'Max file size exceeded.')
                $("#error-message").append("<p>" + fileName + " " + 'exceeds max upload size of 15 MB' + "</p>");
            else { $("#error-message").append("<p>" + ui.errorMessage + "</p>"); }
