Hello,we recently ran into a problem with igCombo, and we are not sure how to deal with it.We want to use a multiselectable combobox dropdown with ticks defined like this:
@(Html.Infragistics() .ComboFor(model => model.Committees) .ID("SubTopicCommitteeCombo") .Width("150") .LoadOnDemandSettings(lods => lods.Enabled(true).PageSize(25)) .DataSourceUrl(Url.Action("GetComboCommittees")) .ValueKey("CommitteeID") .TextKey("FullTitle") .CompactData(true) .EnableClearButton(false) .MultiSelectionSettings(msw => msw.Enabled(true)) .MultiSelectionSettings(msw => msw.ShowCheckBoxes(true)) .DataBind() .Render() )
It all works fine, until we reload the page, submit or fetch any ticked data.Now the problem is basically:So far, everytime we reload the page and fetch data, no matter what we previously selected, the combobox dropdown has no items ticked.Therefore: How does the model property assigned to the combobox dropdown have to look like in C#, so the data is submitted and fetched correctly?
Thanks in advance.
Hello,We tried your sample solution and it works. But when applying the workaround to our project, but we couldn't make it work.
As additional information, we want to add:When setting .Mode(...) to Dropdown in the igGrid inline combobox, we could not bring the value to be set even after multiple edit attempts.
We found that the issues we have with the igGrid inline combobox dropdowns seem to be a known issue since 2013 and we were wondering, if there is any way that the behaviour of the dropdowns will be corrected anytime soon, so we don't have to rely on the workaround you provided?
A sincere thank you to you for your help and time.
We cannot reproduce the issue. I am attaching a working sample based on your code. Please feel free to modify it and send it back, or send a small sample project of your own if you have one.
Hello,I'm sorry, this didn't fix our problem.Adding the event to open the combobox inside the iggrid did not result in the expected behaviour and instead changed nothing. Is there any other way to do this?
And, as a weird sidenote:In a popup we define the following combobox via ComboFor:
@(Html.Infragistics() .ComboFor(m => m.ResponsibleID) .ID("TopicResponsibleCombo") .Width("150") .LoadOnDemandSettings(lods => lods.Enabled(true).PageSize(25)) .DataSourceUrl(Url.Action("GetComboContacts")) .ValueKey("ContactID") .TextKey("FullTitle") .CompactData(false) .EnableClearButton(false) .DataBind() .Render() )
And HERE, it works like a charm. It prefetches all the data correctly and has a combobox search field and all that.The only apparant differences are:- This is a ComboFor instead of a combobox inside an igGrid.- The DataSourceUrl function is available which we use.
I hope this somehow helps understand the problem, so we can fix it once and for all.
I managed to reproduce the issue - it happens only the first time we enter the edit mode. You should load the combo data before that. This could happen on "Rows Rendered" event. I am providing detailed example of the desired behavior:
And the Controller:
I hope this would help.
sorry, I have to specify: The ID is set to 12, which is the ID of the object with the FullName "Hans Müller" and the igGrid definition of that cell is this:
.Columns(column => {...column.For(c => c.SpeakerID).HeaderText("SpeakerID").FormatterFunction("lookupContacts").Hidden(ViewBag.UserSettingsAgendaItem.IsHidden("SpeakerID"));....ColumnSettings(cs => {...cs.ColumnSetting().ColumnKey("SpeakerID").EditorType(ColumnEditorType.Combo).Required(true).ComboEditorOptions(co => co.DataSource(Url.Action("GetComboContacts")).ValueKey("ContactID").TextKey("FullTitle").EnableClearButton(false).Mode(ComboMode.DropDown)).ReadOnly(!ViewBag.PermissionAgendaItem.Write);...
The lookupContacts only maps the given c.SpeakerID to the FullName.
