I want to open the numeric key pad when edit a numeric field using touch screen
Version 15.1.20151.2112
Hello Mauricio,
In 15.2 you don't have to configure this functionality. It is available by default. You can check the following sample http://www.igniteui.com/grid/basic-editing. Enter edit mode and go to "Total Price" cell. You will see that the numeric keys will appear.
Best regards,Martin PavlovInfragistics, Inc.
Hello Martin.
Thanks for your answer.
It is possible that you send an example using vr 15.2
Hello Harold,
This functionality is available out of the box in 15.2 version due to the introduction of the new editors. For 15.1 you need to add type="tel" attribute to the input element of the editor.
Here is how to do it in the igGrid.rendered event:
rendered: function (evt, ui) {
// finding the cell by id.
var cell = ui.owner.cellById(parseInt($(ui.owner.rows()[0]).attr("data-id")), "Price");
// adding type="tel" attribute to the editor
$("#grid1").igGridUpdating("editorForCell", cell, true).find("input").attr("type", "tel");
